Results 1 to 10 of 10
Thread: P0455 code
  1. #1
    suckit
    G6 Newbie
    Nov 2010
    9
    Year
    2004
    Make
    Pontiac
    Model
    G6
    Trim
    V6
    Engine
    3.5L V6 LX9
    Transmission
    4 Speed Auto
    Style
    Sedan
    Color
    Stealth Gray Metallic
    P0455 code
    Hi GUys,
    I've been getting "Check Gas Cap" error messages on the radio display and the "SES" light is on.
    I had the error codes read and the code was P0455.
    I've been reading up about the error on this forum and replaced the gas cap with one from O'Riely's Auto Parts.
    Now a week later I've been getting the same "Check Gas Cap" messages on the radio and the SES light is on again. Also getting the same P0455 error.
    Is it possible that the gas cap I go is bad or do I have to look further now and replace the vent solenoid? Should I have gotten the gas cap from the dealer?
    If it is the vent solenoid where would that be located? Is it by the gas tank or heaven forbid...IN the gas tank?
    Thanks for the info.
  2. #2
    Photobucket
    Photobucket
    suckit
    G6er Addict
    The01Cav's Avatar
    Nov 2009
    Delaware
    2,383
    Name
    Larry Mischler II
    Re: P0455 code
    When it comes to evap leaks, I end up sending the car to the shop. They can smoke the system and figure out where the leak is coming from.
    2009 Ford Mustang Premium Pony 4.0L
    2001 GMC Sierra SL 4.3L
  3. #3
    Global Moderator suckit
    suckit
    G6er 4 Life!
    ahuhn's Avatar
    Apr 2007
    SE Wisconsin
    13,645
    Name
    Andy
    Year
    2006
    Make
    Pontiac
    Model
    G6
    Trim
    GT
    Engine
    3.5L V6 LX9
    Transmission
    4 Speed Auto with Tapshift
    Style
    Convertible
    Color
    Liquid Silver Metallic
    Re: P0455 code
    if you put a non gm gas cap on it that could be it but i tend to see more vent solenoids go bad. sadley that vent is partialy on top of the tank. not as bad as in the tank but still aint easy
    Quote Originally Posted by snowmanG6 View Post
  4. #4
    suckit
    G6 Newbie
    Nov 2010
    9
    Year
    2004
    Make
    Pontiac
    Model
    G6
    Trim
    V6
    Engine
    3.5L V6 LX9
    Transmission
    4 Speed Auto
    Style
    Sedan
    Color
    Re: P0455 code
    Quote Originally Posted by ahuhn View Post
    Thanks guys...
    Yes I went underneath there last night and it doesn't look fun. It wouldn't be so bad if I could get it on a hoist so I would have more room to work. But having the car just on ramps makes it nearly impossible.
    Not sure what to do...I called the dealer and asked if it would still be covered under warranty (for the emissions - I have 67,000 miles on the car) but the guy said he doubted that it would. He said if it was the solenoid that it would be up to $225 to fix but they wouldn't know for sure until they investigated it more.
    The cap seems to be doing it's job and I'd hate to buy another gas cap from the dealer (yes I am cheap and who knows how much that would be from them)....but I'm still not 100% sure the cap isn't right.
    Might just have to suck it up and take it in...
  5. #5
    suckit
    Established G6er
    CruisinG6's Avatar
    Nov 2009
    Northern Illinois
    1,708
    Year
    2009
    Make
    Pontiac
    Model
    G6
    Trim
    Base
    Engine
    2.4L I4 LE5
    Transmission
    4 Speed Auto
    Style
    Sedan
    Color
    Carbon Black Metallic
    Re: P0455 code
    Here's some info on the Emissions Warranty
    http://www.epa.gov/oms/consumer/warr95fs.txt
    Maybe it can help shed some light for ya.
    I wonder if you can just use a fog machine and find your leak that way. haha
  6. #6
    Photobucket
    Photobucket
    suckit
    G6 Beginner
    Aug 2011
    South Carolina
    86
    Name
    Marcus
    Year
    2006
    Make
    Pontiac
    Model
    G6
    Trim
    GT
    Engine
    3.5L V6 LX9
    Transmission
    Style
    Sedan
    Color
    Blue-Gold Crystal Metallic
    XBox LIVE Gamercard
    MDiggity
    Re: P0455 code
    I actually have this same problem. I'm also reporting a P0496 along with the 455.
    I've been told it is most likely the Canister purge valve, up next to the intake. $25 and one bolt.
    I'm going to replace it this week and get back to you.
  7. #7
    suckit
    G6 Newbie
    Sep 2013
    1
    Year
    1964
    Make
    Pontiac
    Model
    G6
    Trim
    Base
    Engine
    2.0L I4 S/C LSJ
    Transmission
    4 Speed Auto
    Style
    Coupe
    Color
    Re: P0455 code
    Did replacing the canister purge valve eliminate the code po455?
  8. #8
    suckit
    G6 Newbie
    Jul 2014
    1
    Year
    2006
    Make
    Pontiac
    Model
    G6
    Trim
    GT
    Engine
    3.5L V6 LX9
    Transmission
    Style
    Sedan
    Color
    Re: P0455 code
    My wife's 06 GT sedan is have the same issue. We replaced the gas cap with the OEM part from the dealership (~$20) and the canister purge valve. Still throwing the code.
    It is worth noting that apparently GM has a patent on the diameter of the gas cap so any aftermarket cap will most likely trip the P0455 code and or the "Check Gas Cap" message. I haven't noticed any performance issues (yet) though.
  9. #9
    suckit
    G6 Newbie
    Mar 2015
    2
    Year
    2008
    Make
    Pontiac
    Model
    G6
    Trim
    Base
    Engine
    2.4L I4 LE5
    Transmission
    4 Speed Auto
    Style
    Sedan
    Color
    Gold Mist Metallic
    Re: P0455 code
    My wife's 2008 G6 2.4L is currently throwing po455. I have replaced the gas cap with another OEM gas cap and replaced the vent solenoid. After clearing the code, the light comes back on next time car is driven any distance. I replaced the purge valve about three months ago to fix a couple other codes. I don't think po455 was one of them, but I could be mistaken. I'm not getting any "check gas cap" message on the info screen, just the engine light. Could the new purge valve have failed causing only the po455 code? Alternatively, could the code be something that will go away once the new vent solenoid gets broken in? I believe the evap canister was included as part of the new vent solenoid. Also, someone said they thought this code can be caused by a leak OR a blockage of some sort. The scanner does say as part of the code "large leak / no flow."
  10. #10
    suckit
    G6 Newbie
    Mar 2015
    2
    Year
    2008
    Make
    Pontiac
    Model
    G6
    Trim
    Base
    Engine
    2.4L I4 LE5
    Transmission
    4 Speed Auto
    Style
    Sedan
    Color
    Gold Mist Metallic
    Re: P0455 code
    Well, I checked my receipts and I got the purge valve from Auto Zone. So I decided to exchange it for a new one, and the light's been off for a few days now. When I reset it after the new gas cap and vent solenoid, it was back on the next day. I guess if it happens again I'll order an AC Delco purge valve from somewhere. At least the original one lasted 7 years. The Auto Zone one didn't even last 2 months.
