Results 1 to 15 of 15
Thread: Light engine knocking at idle
  1. #1
    Photobucket
    G6 Newbie
    brothernewf's Avatar
    May 2011
    Richmond Hill
    7
    Name
    Matthew
    Year
    2008
    Make
    Pontiac
    Model
    G6
    Trim
    Base
    Engine
    2.4L I4 LE5
    Transmission
    4 Speed Auto
    Style
    Sedan
    Color
    Storm Gray Metallic
    Question Light engine knocking at idle
    i just bought my 08 G6 2.4L with 122990 KM and it has a slight knocking noise while its idling. it seems to go away when i accelerate but i dont know what it is. at first i thought maybe the gas because Gm calls for 91 octane and i had 87 inthere but then i put some 94 in there and its still knocking. it sounds like a very low volume helocopter lol.
    <<<<<BROTHERNEWF>>>>>
  2. #2
    Established G6er
    Nov 2007
    San Juan Puerto Rico
    1,638
    Re: Light engine knocking at idle
    how is your oil pressure and level?
    Not to create panic, but knocking at idle. when the engine is just spinning and not doing anywork usually means problems
  3. #3
    Photobucket
    G6 Newbie
    May 2011
    Richmond Hill
    7
    Name
    Matthew
    Year
    2008
    Make
    Pontiac
    Model
    G6
    Trim
    Base
    Engine
    2.4L I4 LE5
    Transmission
    4 Speed Auto
    Style
    Sedan
    Color
    Storm Gray Metallic
    Oil level is good plus its got 56% oil life left. I am going to take it to a gm dealer and hopefully its something that's covered under the powertrian warranty!!!
  4. #4
    Photobucket
    Active G6er
    Abyssul's Avatar
    Jul 2010
    South Carolina
    622
    Year
    2006
    Make
    Pontiac
    Model
    G6
    Trim
    GT
    Engine
    3.5L V6 LX9
    Transmission
    4 Speed Auto with Tapshift
    Style
    Sedan
    Color
    Stealth Gray Metallic
    I'm pretty sure that 4 cylinder runs on 87 octane... Where does it call for 91 octane? The only one that would need that (maybe) is the 3.6L
  5. #5
    Moderator Photobucket
    Photobucket
    G6 Post Whore
    dre256's Avatar
    Mar 2006
    Mount Laruel, NJ
    4,685
    Year
    2006
    Make
    Pontiac
    Model
    G6
    Trim
    GTP
    Engine
    3.9L V6 LZ9
    Transmission
    Style
    Coupe
    Color
    Electric Blue Metallic
    The G6 2.4L calls for 87 regular. No G6 trim calls for 91-93 octane
    Only the 2.4L G5, Colbalt SS (non supercharged) calls for 91-93 octance but they are also like 10 more HP.
    Knocking is strange. I belive you are hearing something that sounds like knocking but isnt, if that makes sense. The new engines with the knock sensors will hear a knock well before any person can. And if the sensor is malfunctioning a check engine light will come on.
    Without more info, I would maybe think at that milage you are hearing the valves. Might have a bit of valve tapping going on, that could sound like a minor knock and will go away under load.
    2006 G6 GTP: Traded
    2013 Mustang GT
    Gotta have it Green color
    Brembo brake package
    420 HP 5.0L
    Ford Racing Power Pack
  6. #6
    Established G6er
    Nov 2007
    1,638
    Get that car to your GM dealer, engine its covered under powertrain warranty. Be prepared to present envidence of oil changes.
    An audio file will help a little here, but these engines are quite loud at idle.
    The knocking sound dull or its has some sort of high tone to it?
  7. #7
    Photobucket
    G6 Newbie
    May 2011
    Richmond Hill
    7
    Name
    Matthew
    Year
    2008
    Make
    Pontiac
    Model
    G6
    Trim
    Base
    Engine
    2.4L I4 LE5
    Transmission
    4 Speed Auto
    Style
    Sedan
    Color
    Storm Gray Metallic
    Its hard to say, its sounds low but seems to be getting worse. As for the proof of oil changes, I don't have any as I just got the car last friday. Its going in to the dealer tomorrow morning and if its serious and not covered I'm goin back to where I bought it and having somethin done there. I know there is a 30 day consumers warranty regardless of what you buy.
    Also there is a squeeking noise comming from the rear whenever I hit bumps and its getting anoying. I wonder if the seals are dry....hmmm..
  8. #8
    Photobucket
    Photobucket
    Medium-Rare G6er
    Feb 2011
    Rock Island,IL
    397
    Name
    Jordan
    Year
    2007
    Make
    Pontiac
    Model
    G6
    Trim
    GTP
    Engine
    3.6L V6 LY7
    Transmission
    6 Speed Auto with Tapshift
    Style
    Coupe
    Color
    Black
    does it do it when it cold? does it knock right away when u stop? also can u hear it just by opening the hood or is audible from inside the car?
  9. #9
    Photobucket
    G6 Newbie
    May 2011
    Richmond Hill
    7
    Name
    Matthew
    Year
    2008
    Make
    Pontiac
    Model
    G6
    Trim
    Base
    Engine
    2.4L I4 LE5
    Transmission
    4 Speed Auto
    Style
    Sedan
    Color
    Storm Gray Metallic
    Its more noticable when its up to tempature and more so when its in park or nuetral
  10. #10
    Photobucket
    Photobucket
    Medium-Rare G6er
    Feb 2011
    Rock Island,IL
    397
    Name
    Jordan
    Year
    2007
    Make
    Pontiac
    Model
    G6
    Trim
    GTP
    Engine
    3.6L V6 LY7
    Transmission
    Style
    Coupe
    Color
    Black
    Quote Originally Posted by brothernewf View Post
    so it does it when its cold too correct?
  11. #11
    Photobucket
    G6 Newbie
    May 2011
    Richmond Hill
    7
    Name
    Matthew
    Year
    2008
    Make
    Pontiac
    Model
    G6
    Trim
    Base
    Engine
    2.4L I4 LE5
    Transmission
    4 Speed Auto
    Style
    Sedan
    Color
    Storm Gray Metallic
    Hot really. Just when its up to operating temp
  12. #12
    Photobucket
    Photobucket
    Medium-Rare G6er
    Feb 2011
    Rock Island,IL
    397
    Name
    Jordan
    Year
    2007
    Make
    Pontiac
    Model
    G6
    Trim
    GTP
    Engine
    3.6L V6 LY7
    Transmission
    Style
    Coupe
    Color
    Black
    mine makes a sound similar to that. its pretty much the exact same thing you described but im not worried about it since it doesnt do it when its cold. so idk
  13. #13
    Photobucket
    G6 Newbie
    May 2011
    Richmond Hill
    7
    Name
    Matthew
    Year
    2008
    Make
    Pontiac
    Model
    G6
    Trim
    Base
    Engine
    2.4L I4 LE5
    Transmission
    4 Speed Auto
    Style
    Sedan
    Color
    Storm Gray Metallic
    Not to sure myself. Its at the gm repair center right now. Well see what's wrong and I will post!
  14. #14
    Photobucket
    Photobucket
    Medium-Rare G6er
    Feb 2011
    Rock Island,IL
    397
    Name
    Jordan
    Year
    2007
    Make
    Pontiac
    Model
    G6
    Trim
    GTP
    Engine
    3.6L V6 LY7
    Transmission
    Style
    Coupe
    Color
    Black
    just let me know that would be great
  15. #15
    Photobucket
    G6 Beginner
    Mar 2011
    Detroit, Mi
    32
    Name
    Michael
    Year
    2008
    Make
    Pontiac
    Model
    G6
    Trim
    Base
    Engine
    2.4L I4 LE5
    Transmission
    4 Speed Auto
    Style
    Sedan
    Color
    Ivory White
    So what did the dealership say? My first thought was your idle air line being clogged but if its an acctual knock then its something more serious. Im curious what they said (especially since I own a 2.4)
