Results 1 to 5 of 5
Thread: Is it possible to resurface/cut drilled and slotted brake rotors?
  1. #1
    Photobucket
    suckit
    suckit
    Active G6er
    thestig's Avatar
    Aug 2008
    Butler, PA
    939
    Name
    James
    Year
    2006
    Make
    Pontiac
    Model
    G6
    Trim
    GTP
    Engine
    3.9L V6 LZ9
    Transmission
    4 Speed Auto with Tapshift
    Style
    Coupe
    Color
    Electric Blue Metallic
    I have the R1 Concepts rotors that are drilled and slotted. I have been very happy with their braking power, even on the race track. However recently they have started to pulsate just like the GM stock rotors do after a little while. They took longer than the GM rotors to start pulsating and are definitely 1000 times better than GM rotors.
    My question: Is it possible to have the stealership cut these rotors just like they cut stock rotors? Will it cause problems with the holes? Will the rotors crack or something?
    Custom 93 Dyno Tune, Red Painted K&N Intake, GT-R Exhaust, CMS Springs, Racingline STB + Race MMI's, Sacchi S45 Black Wheels, Hankook Ventus V12 245/45ZR18, Delete Intake Resonator, Mobil 1, Red Calipers, Body Color Matched Headlights/Engine/Battery Covers/Interior Trim, Debadged, Tinted Tails, AIT Hood, ZZP Shift Kit, R1 Concepts Rotors + Pads, Summit Racing Trans Cooler, Denso Iridium Plugs, 30% Tint, Suede Upholstered Steering Wheel, Rear STB
  2. #2
    Photobucket
    Photobucket
    Photobucket
    suckit
    Medium-Rare G6er
    RedMoon Roku's Avatar
    Jan 2011
    Evansville, Indiana
    251
    Name
    Darius Neighbors
    Year
    2006
    Make
    Pontiac
    Model
    G6
    Trim
    GT
    Engine
    3.5L V6 LX9
    Transmission
    Style
    Coupe
    Color
    Sport Red Metallic
    XBox LIVE Gamercard
    Darikun PontiG6
    Re: Is it possible to resurface/cut drilled and slotted brake rotors?
    It can be done with a convential brake lathe or an on car brake lathe. I believe carquest does it if there is one near you. If you're still in doubt look it up online and see for yourself. I have Disc Italia Slotted Rotors on mine, no issues yet on them since they're still new.
    Roku's Mods: K&N air intake system, Eibach lowering springs, 225/45R18 Bridgestone Potenza RE970AS Pole Postion Tires, 18in OZ Ultraleggera wheels (black), Disc Italia brake pads and slotted rotors, debadged, 30% window tint, Eagle Eye headlights (black), DDM 6000K HID low headlights, Notto SE 10000K HID fog lights, LED taillights, Koni shock absorbers and front struts, Racingline strut tower bar and grounding kit, Sirius Satellite Radio, BMD front end links, BMD steel braided brake lines, Brembo four piston front brake calipers, MPD ram air hood (body color), upper and lower recessed grilles (body color) GM Ground Effects kit (body color), Hammerhead flushmount spolier (body color), Customized Pontiac Concept Dart (Black w/ Carbon Fiber), Remin carbon fiber dash kit, WAMS ECM 91 Octane Tune, Borla pro xs dual muffler exhaust with vibrant resonator
    Roku's progression:http://www.g6performance.com/forum/s...36&pagenumber=
  3. #3
    Moderator suckit
    suckit
    G6 Post Whore
    dre256's Avatar
    Mar 2006
    Mount Laruel, NJ
    4,685
    Year
    2006
    Make
    Pontiac
    Model
    G6
    Trim
    GTP
    Engine
    3.9L V6 LZ9
    Transmission
    Style
    Coupe
    Color
    It depends. If only requires a few thousands to resurface then it can be done. If your talking about .010 thousands now your getting questionable.
    The downside on resurfacing cross drilled and slotted rotors is your taking away the depth of the slots which will alow for more heat build up. So each time they get resurfaced there going to lose more and more heat transfer ability
    2006 G6 GTP: Traded
    2013 Mustang GT
    Gotta have it Green color
    Brembo brake package
    420 HP 5.0L
    Ford Racing Power Pack
  4. #4
    Established G6er
    Nov 2007
    San Juan Puerto Rico
    1,638
    It can be done. But I have seen that the machine is different. Instead of a metal point shaving the surface, they use a stone like block and fluid. The rotor is spun much faster than the traditional machine
  5. #5
    suckit
    Medium-Rare G6er
    Feb 2008
    104
    Any of your reputable brake shops, or stealerships, can tell you if yours can be turned. SO yes, if they aren't too bad, they can be turned.
    GL,
    ominousone
