3.5 Spark Plug Change HELP!!
Re: 3.5 Spark Plug Change HELP!!
Originally posted by karlmajors View PostI thought when you bough plugs they came pre-gapped? unless my understanding of a gap is not correct! Uh-oTRADED IN BUT NEVER FORGOTTEN: 2006 GT Coupe in granite metallic, 15/5% tint, vinyl side marker deletes, Doctor Speed Stage 3 CAI, RED calipers by DupliColor, RED LED interior lights, 45 LED tail lights, WideView 8000K HID coversion kit, Nokya Artic White fogs installed, running MoBil 1, FIRST ever granite metallic color matched headlights!! Color matched eyelids just finished! GT-R Exhaust installed. R1 Concepts drilled and slotted zinc plated front rotors.
.060 ;-)
Check your manual its all listed there.
It took me around 30 mins, just take your time, wear some gloves to protect your hands, lots of sharp stuff to cut you.MODSGT-R, HIDS 6000K, 8000K FOGS, 35% TINT, K&N INTAKE, CRAB HEAT SHIELD, Cquence Rotors
They should, but it's always good to double check. When I bought my plugs, I bought a gap tool just to check, they were all correct.MODSGT-R, HIDS 6000K, 8000K FOGS, 35% TINT, K&N INTAKE, CRAB HEAT SHIELD, Cquence Rotors
Originally posted by LoJac963 View Postsome plugs to come pre-gapped but its good practice to always check them either way. Most of the time you'll find one or two or even more that are incorrectly gappedOriginally posted by karlmajors View PostI am planning on picking up the AC delcos from autozone. Should i be concerned? What should the correct gap be for my '06 G6 with the 3.5
the post directly above your post answered your questionTRADED IN BUT NEVER FORGOTTEN: 2006 GT Coupe in granite metallic, 15/5% tint, vinyl side marker deletes, Doctor Speed Stage 3 CAI, RED calipers by DupliColor, RED LED interior lights, 45 LED tail lights, WideView 8000K HID coversion kit, Nokya Artic White fogs installed, running MoBil 1, FIRST ever granite metallic color matched headlights!! Color matched eyelids just finished! GT-R Exhaust installed. R1 Concepts drilled and slotted zinc plated front rotors.
get back to work.. and make sure youve got gloves on for the rears.. i bled a lil getting them off...
