Results 1 to 9 of 9
Thread: Caliper rebuild advice
  1. #1
    Retired Moderator Photobucket
    Photobucket
    Photobucket
    G6 Post Whore
    zlatsky's Avatar
    Jul 2008
    Houston
    5,522
    Year
    2009
    Make
    Other
    Transmission
    5 Speed Manual
    Style
    Sedan
    XBox LIVE Gamercard
    zlatsky
    My brakes pretty much suck and the seal around the piston is completely torn. Rebuild kits are only $7 as opposed to getting another new caliper. But I've got no clue how to rebuild it.
    Any advice here?
  2. #2
    Global Moderator Photobucket
    Photobucket
    G6er 4 Life!
    ahuhn's Avatar
    Apr 2007
    SE Wisconsin
    13,645
    Name
    Andy
    Year
    2006
    Make
    Pontiac
    Model
    G6
    Trim
    GT
    Engine
    3.5L V6 LX9
    Transmission
    4 Speed Auto with Tapshift
    Style
    Convertible
    Color
    Liquid Silver Metallic
    Re: Caliper rebuild advice
    buy a new one. when it comes to brakes if you dont know what your doing it could end badley. plus new calipers really arnt that expensive
    Quote Originally Posted by snowmanG6 View Post
  3. #3
    Photobucket
    G6er Addict
    Apr 2008
    Algonquin,IL
    2,557
    They r not that bad to repair but i with Andy
    87 Jeep Comanche Metric Ton
    90 Eagle Talon TSI
    09 G6 Progression(New Car)
    My Progression
  4. #4
    Photobucket
    Photobucket
    Established G6er
    black07g6gtp's Avatar
    Mar 2007
    Georgia
    1,239
    Name
    Charlie
    Year
    2007
    Make
    Pontiac
    Model
    G6
    Trim
    GTP
    Engine
    3.6L V6 LY7
    Transmission
    6 Speed Auto with Tapshift
    Style
    Sedan
    Color
    Black
    XBox LIVE Gamercard
    charliebrownatl
    Rebuild is very easy. When you get the caliper off the car, use an air compressor through the fluid entry to blow the piston out. Remove old piston dust boot and piston ring. Clean the inside of the caliper out. Apply brake fluid generously around the new seal and insert/seat. Coat the inside wall of where the piston goes with brake fluid. Put new dust boot around piston. Push piston back in to caliper. Push the dust boot in to place. Reinstall on car. Bleed brakes. Done! This will save you a lot of money.
  5. #5
    Photobucket
    G6er 4 Life!
    ahuhn's Avatar
    Apr 2007
    SE Wisconsin
    13,645
    Name
    Andy
    Year
    2006
    Make
    Pontiac
    Model
    G6
    Trim
    GT
    Engine
    3.5L V6 LX9
    Transmission
    Style
    Convertible
    Color
    Quote Originally Posted by black07g6gtp
    make damn sure you have a block of wood or a few rags there to prevent it from shooting out and smacking the other side of the caliper and damaging it
  6. #6
    Photobucket
    Photobucket
    G6 Post Whore
    zlatsky's Avatar
    Jul 2008
    Houston
    5,522
    Year
    2009
    Make
    Other
    Transmission
    5 Speed Manual
    Style
    Sedan
    XBox LIVE Gamercard
    zlatsky
    The more I look at this the more I realize how basic a caliper is.
  7. #7
    Photobucket
    G6er 4 Life!
    ahuhn's Avatar
    Apr 2007
    SE Wisconsin
    13,645
    Name
    Andy
    Year
    2006
    Make
    Pontiac
    Model
    G6
    Trim
    GT
    Engine
    3.5L V6 LX9
    Transmission
    Style
    Convertible
    Color
    yeah there pretty simple
    •Remove the brake caliper piston from the caliper bore by directing low pressure compressed air into the caliper bore through the fluid inlet hole.
    •Remove the retaining ring that secures the dust boot to the caliper housing.
    •Remove the piston dust boot seal (2) from the seal counterbore in the caliper (5). Discard the boot seal.
    •Using a small wooden or plastic tool, remove the piston seal (4) from the caliper bore . Discard the piston seal.
    •Remove the bleeder valve cap (6).
    •Remove the bleeder valve (7).
    Important: Do not use abrasives to clean the brake caliper piston.
    •If cracks, scoring, pitting, excessive rust, and/or excessive corrosion are present in the caliper bore, replace the caliper assembly.
    •If light rust or light corrosion are present in the caliper bore, attempt to remove the imperfection with a fine emery paper. If the imperfection cannot be removed, replace the caliper assembly.
    •Clean the brake caliper piston bore and seal counterbore, and the caliper piston with denatured alcohol, or equivalent.
    •Dry the caliper piston bore and counterbore, and the piston with non-lubricated, filtered, compressed air.
    •Inspect the caliper piston for cracks, scoring, and/or damage to the plating. Replace the caliper piston if any of these conditions exist.
    •Inspect the caliper mounting holes for cracks, scoring, pitting, rust and/or excessive corrosion. Replace the caliper assembly if any of these conditions exist
    INSTALL
    •Lubricate the new piston seal (4) with Delco Supreme 11 GM P/N 12377967 (Canadian P/N 992667), or equivalent DOT-3 brake fluid from a clean, sealed brake fluid container.
    •Install the lubricated, new piston seal (4) into the caliper bore.
    •Apply a thin coat of Delco Supreme 11 GM P/N 12377967 (Canadian P/N 992667), or equivalent DOT-3 brake fluid from a clean, sealed brake fluid container onto the outer surface area of the caliper piston (3).
    •Install the bottom half of the caliper piston (2) into the caliper bore.
    •Install the new piston dust boot seal (1) over the caliper piston (2).
    •Compress the caliper piston (2) to the bottom of the caliper bore.
    •Fully seat the piston dust boot seal (1) into caliper counterbore.
  8. #8
    Photobucket
    Photobucket
    G6 Post Whore
    zlatsky's Avatar
    Jul 2008
    Houston
    5,522
    Year
    2009
    Make
    Other
    Transmission
    5 Speed Manual
    Style
    Sedan
    XBox LIVE Gamercard
    zlatsky
    thanks!
  9. #9
    Photobucket
    G6er 4 Life!
    ahuhn's Avatar
    Apr 2007
    SE Wisconsin
    13,645
    Name
    Andy
    Year
    2006
    Make
    Pontiac
    Model
    G6
    Trim
    GT
    Engine
    3.5L V6 LX9
    Transmission
    Style
    Convertible
    Color
