Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Thread: 2002 Grand Prix ABS and Traction control lights
  1. #1
    markpetersonii
    Guest
    In my mom's car the "ABS" and "Trac off" lights are on and staying on. She can't shut them off (i.e. tried turning on the Traction control and it won't let her.
    The "Service Engine Soon" light is on but she said that the previous owner said it was always on for them too.
    Anyone?
  2. #2
    Photobucket
    G6 Post Whore
    grfnkl's Avatar
    Oct 2006
    Havelock, NC Formerly: Union, NJ & San Juan, PR
    4,089
    Name
    Paul
    Year
    2009
    Make
    Acura
    Model
    RDX
    Trim
    Base
    Engine
    2.3L I4 T/C Acura K23A1
    Transmission
    6 Speed Auto with Tapshift
    Style
    SUV
    Color
    Silver Jade Metallic
    Re: 2002 Grand Prix ABS and Traction control lights
    ABS and Trac Off light more then likely are due to either a bad hub bearing, a bad wheel sensor (either speed or ABS). It could also be a bad connection that can cause the light to come on intermittenly. SES light is more the likely something emissions related.
  3. #3
    markpetersonii
    Guest
    Quote Originally Posted by grfnkl
    Quote Originally Posted by Mom
    Is any of this going to cost me a fortune?
  4. #4
    Photobucket
    G6 Post Whore
    grfnkl's Avatar
    Oct 2006
    4,089
    Name
    Paul
    Year
    2009
    Make
    Acura
    Model
    RDX
    Trim
    Base
    Engine
    Transmission
    Style
    SUV
    Color
    depends on which one is the culprit. A bearing itself will go between 200-300 bucks sometimes higher if they mark it up. I'm not sure the prices on the sensors. Best advice is bring it someplace where they can scan for the SES code and scan for ABS codes as well. this way you have an idea of what's going on to start.
  5. #5
    Photobucket
    Active G6er
    uzun1986's Avatar
    Nov 2007
    WINDSOR, ONTARIO
    895
    Name
    Kyle
    Year
    2008
    Make
    Pontiac
    Model
    G6
    Trim
    GXP
    Engine
    3.6L V6 LY7
    Transmission
    Style
    Coupe
    Color
    Liquid Silver Metallic
    Had the same problem on my car speed sensor, you have to get a new wheel bearing go get the code read and you will know which one
    GMPP Cat-Back Exhaust, MMS Headers, 3" DP with Electric cutout, Full CRAB Intake, RacingLine Street Motor Mounts, NRG Engine Damper, RacingLine Strut Tower Bar, Vector 91 ECM/TCM Tune/HSRK, R1Concept Brakes, HAWK Ceramic Pads, DW's 245/45/18 with TC Wheels, Poly. Sway Bar Bushings, 6000K HID's Lows & Fogs 35watts & 55watts 6,000K Hi-beams
    Future: Slicks for the track & Maybe alittle Nitrous
  6. #6
    markpetersonii
    Guest
    Mom said thank you!
  7. #7
    Guest
    Quote Originally Posted by uzun1986
  8. #8
    markpetersonii
    Guest
    Quote Originally Posted by oldmanvette1975
    You wouldn't happen to know how much that's going to run would you?
  9. #9
    Global Moderator Photobucket
    Photobucket
    G6er 4 Life!
    ahuhn's Avatar
    Apr 2007
    SE Wisconsin
    13,645
    Name
    Andy
    Year
    2006
    Make
    Pontiac
    Model
    G6
    Trim
    GT
    Engine
    3.5L V6 LX9
    Transmission
    4 Speed Auto with Tapshift
    Style
    Convertible
    Color
    sensor is built into the hub bearng gonna say $300 +-100 depending where you get it etc etc
    anyway those grand ams were GREAT for breaking the wires to the wheel speed sensor inside the insulation so it you couldnt actually tell. i would typicaly try to sell both the hub bearing adn the wires at the same time because if i found the hub was bad it was easy for the wire to still be bad and then the car comes back.
    so im gonna vote for hub bearing or the wires to it
    Quote Originally Posted by snowmanG6 View Post
  10. #10
    markpetersonii
    Guest
    Quote Originally Posted by ahuhn
    OK, sounds good, I'll let my mom know. BTW its a Grand Prix...
  11. #11
    Photobucket
    G6er 4 Life!
    ahuhn's Avatar
    Apr 2007
    SE Wisconsin
    13,645
    Name
    Andy
    Year
    2006
    Make
    Pontiac
    Model
    G6
    Trim
    GT
    Engine
    3.5L V6 LX9
    Transmission
    Style
    Convertible
    Color
    same car different badges
  12. #12
    markpetersonii
    Guest
    HAHA, thanks though!
  13. #13
    Guest
    Quote Originally Posted by markpetersonii
    When I had the dealer do it on my Monte Carlo, it was just under $500.00...OUCH
    To make it even better, a week later the problem was back and it turned out to be the wire going to the wheel speed sensor was rubbing on the control arm and cause an intermitant break in the circuit. A little solder and shrink tubing and problem solved BUT I didn't get my $500 bucks back from the dealer GOOD LUCK
  14. #14
    Photobucket
    Photobucket
    Active G6er
    Jul 2009
    Toledo
    907
    Name
    Jordan
    Year
    2007
    Make
    Pontiac
    Model
    G6
    Trim
    GT
    Engine
    3.5Lvvt V6 LZ4
    Transmission
    Style
    Sedan
    Color
    Techno Gray Metallic
    XBox LIVE Gamercard
    HoldenHSVGTS
    Had the same issue with my '01 GP. It was the wire going into the hub. The bearing was like $180 I think. They aren't hard to put on if you know how. I did it four times on the GP. Make sure to get one with a warranty.
    ISimple Ipod adapter, Heat wrapped Injen, CRABs Option 3, ?% Tint, 6000K HIDs,GT-R, Tinted Tails, Rear badge delete, Plastidiped grills and front dart, Brembos, Pulse p5 17"s, racingline MMIs
  15. #15
    markpetersonii
    Guest
    Wow, so this was obviously a big problem. Thanks guys!
