Is this normal? I saw a stream of water coming out of the muffler the other day. I know it's normal to have some condensation coming out of the pipes, but from the muffler?
Water coming out of muffler
Re: Water coming out of muffler
I think this this has something to do with the A/C. I don't think it's a bad thing.
Edit: Wait, I just inspected your picture further. This is coming out of the muffler, not the tail-pipe. Now I have no idea.
Edit, Edit: Yes, I'm aware you said muffler. It's early, aha.Modifications:
[Completed] CRAB 03/04 + WMS 91 Octane Tune + MPD Hood w/ Hood Struts + GT-R Exhaust + Red Interior Lighting + De-Badged + Overlays + Chrome Window Trim + 20% Tint + Racingline Strut Bar
[In Progress] Racingline Mount Inserts / Wiring Kit
[Later Days] Audio Controls + G6 Mats + New Rims + Tail-Light Replacement + Street Glow + Trunk Sub
It happens
'08 G8 GT... 1 7/8" Kooks Blue Ceramic Coated Long tube Headers... 3" Xpipe...Magnaflow axle backs...Rotofab CAI...Heater hose relocate. Ported throttle body, intake manifold, Custom grind cam 227/237 .620/.604 LSA 113 +3, Circle D 3200 stall, 3.45 rear gear,Tuned by Redline
Dyno 438 WHP 415 WTQ
'15 Chevy SS Some Like It Hot Red Holden Grill & trunk badge... Solo performance axle backs... Rotofab Intake, Mobile attractions front splitter
Originally posted by NeverL8Condensation... Very normal. It's why they build the hole in the bottom of the muffler at the factory.
Originally posted by ahuhnso i just realized there a drawer in my room that has nothing in it but tequila, condoms and a blow up doll. cant figure out if thats a good thing or not
Originally posted by snowmanG6Originally posted by NeverL8Condensation... Very normal. It's why they build the hole in the bottom of the muffler at the factory.2006 Malibu Maxx SS
Debadged, 20% Tint Front and Rear, Full CRAB Intake, K&N Oil Filter, K&N Air Filter, R1 concepts cross-drilled and slotted rotors, EBC red stuff pads, Red painted Calipers, Garmin Nuvi GPS, Painted engine cover with SS emblem.
ummm guys... you can actually SEE the hole in the muffler in his picture.... and if you think your muffler is different... go look under the car and you'll see the little hole in your muffler too...
LOL2006 G6 GTP 6spd. Black on Black
dude r u on crack ur muffler should not have a hole in it. i know for a fact my muffler does not have a hole in it.
[youtube:3ap5f0e9]http://www.youtube.com/watch?v=8x8t2eZP_zs[/youtube:3ap5f0e9]
The hole is supposed to be there. Even a slight temperature difference between the outside air, and the air in your muffler, will cause condensation, and if that hole wasn't there, you'd risk having water flow out of the muffler! Or, it could flow the other way, back toward the engine, and, you'd be screwed.
again, there is enough flow from the exhaust pressure to blow out any water in the muffler. if u get water in ur exhaust to reach the motor from the exhaust condensating u have other things to be worrying about. like why there is enough water in there to climb 2 vertical feet. on my muffler there is no holes, and i am sure the GT-R muffler does not have holes on it. the little pin hole on the stock muffler is either a opps or a GM design. all in all a little water in the exhaust system is not going to hurt anything, unless its in the motor its self
Originally posted by snowmanG6...the little pin hole on the stock muffler is either a opps or a GM design. all in all a little water in the exhaust system is not going to hurt anything, unless its in the motor its self
If the hole wasn't there, you potentially could have quite a bit of water sloshing around.
http://auto.howstuffworks.com/muffler3.htm
The fact that water is coming out (even pouring out) should be a major concern. My '98 Ford ZX2 and my '01 Pontiac Grand Prix both had a hole. I have not checked my G6 yet...
