WAMS
Page 1 of 2 12 LastLast
Results 1 to 15 of 22
Thread: How Does Traction Control Work?
  1. #1
    Photobucket
    Medium-Rare G6er
    Feb 2009
    109
    Just wondering what it does to keep traction. I know some systems cut spark timing, some actuate the brakes... Just wondering what it is that the G6 uses to keep traction.
  2. #2
    Photobucket
    Medium-Rare G6er
    EvolutionOX's Avatar
    Apr 2008
    Novi, MI
    354
    Name
    Tony
    Year
    2005
    Make
    Pontiac
    Model
    G6
    Trim
    GT
    Engine
    3.5L V6 LX9
    Transmission
    4 Speed Auto with Tapshift
    Style
    Sedan
    Color
    Ivory White
    Re: How Does Traction Control Work?
    Gives and Takes away power from the slipping wheel(s) its all in the transmission. Thats why I hit that nice little TC button
  3. #3
    Photobucket
    Active G6er
    Apr 2008
    Ankeny Iowa
    583
    Well it depends on what trim level you have. For 2007 the SE had the option of T/C{NW7} and it's engine-torque-modulated. The GT has full function {NW9} engine-torque and brake-modulation and the GTP uses stabili track. You should at least fill out your cars profile so we know what trim and year of G6 you have.
    Mark.
    http://[img]http://i188.photobucket.....jpg[/img]
    2007 G6 GT Sedan {My driver}
    2007 Chevrolet Equinox 2LT {Wife's driver}
    1978 T/A {My toy}SOLD
    1984 Camaro (New toy)
  4. #4
    Photobucket
    Photobucket
    Photobucket
    Established G6er
    Feb 2006
    Macomb Township, MI
    1,967
    If you have the standard TC (IE no stabilitrak/ESC) it uses the ABS sensor to look for variations in wheel speed IE slip and modulates engine power accordingly using spark cut/fuel cut or closing the TB (depends on the car which modes it uses) it also has the ability to upshift the transmission in automatic equipped vehicles. If you have Stailitrak/ESC add in the ability of the system to apply individual or more brake calipers to control the vehicles yaw.
    Chris White
    http://www.GTOShiftLight.com
    2006 Spice Red GTO - Stock
    2012 Cherokee SRT8 - Stockish
  5. #5
    Why not Zoidberg? Photobucket
    Photobucket
    Photobucket
    Photobucket
    Photobucket
    G6er 4 Life!
    WoodburyMan's Avatar
    Jun 2007
    Woodbury, CT
    23,765
    Name
    Erik
    Year
    2009
    Make
    Pontiac
    Model
    G8
    Trim
    GT
    Engine
    6.0L V8 L76
    Transmission
    6 Speed Auto with Tapshift
    Style
    Sedan
    Color
    Sport Red Metallic
    XBox LIVE Gamercard
    WoodburyMan
    I have to turn it off in the spring all the fracking time... the sand sets it off and I go to start from a stop sign pulling onto a main road with traffic and f***er makes me go 2 miles and hour cause it slips for a whole .1 seconds on sand and it forces the other cars to brake once I get onto the road cause it WILL NOT let me accel, instead the stupid dash T/C light farts out me with that annoying sound.
    2009 G8 GT Sport Red Metallic, Premium Package
    Appearance: Complete LED Conversion, 6000K DDM HID Low Beams, Painted Calipers
    Electronics: Factory Bluetooth Retrofit, Atari Gauge Retrofit, Factory iPod Control/Display
    Go Stuff: Custom DiabLew ECM/TCM 93 Octane Tune, NGK TR6IX Plugs, MSD Plug Wires, Vararam Ram Air OTR Intake, BMR Strut Tower Bar, Corsa Catback
    Stop Stuff: DBA 4000SX Slotted + Drilled Rotors, Hawk Ceramic Pads.
    Wheels: (Winter)Moda MD17 Black w/ 235/55/17 Blizzak WS70s. (Summer)Stock 18."
    2005 CGM GTO.
  6. #6
    Photobucket
    Medium-Rare G6er
    Feb 2009
    109
    So there are different versions then?
    I updated my profile, so it's got all my goods hanging out. :P
  7. #7
    Global Moderator Photobucket
    Photobucket
    G6er 4 Life!
    ahuhn's Avatar
    Apr 2007
    SE Wisconsin
    13,541
    Name
    Andy
    Year
    2006
    Make
    Pontiac
    Model
    G6
    Trim
    GT
    Engine
    3.5L V6 LX9
    Transmission
    Style
    Convertible
    Color
    Liquid Silver Metallic
    Traction Control System (TCS)
    When drive wheel slip is detected while the brake is not applied, the electronic brake control module (EBCM) will enter traction control mode. The traction control system (TCS) controls vehicle traction by applying brakes and limiting engine torque to the drive wheels. The EBCM performs the following TCS operations:
    • The EBCM requests the engine control module (ECM) to reduce the amount of torque to the drive wheels via serial data messages.
    • The ECM reduces torque to the drive wheels by retarding spark timing and throttle actuator control (TAC).
    • The ECM reports the amount torque delivered to the drive wheels via serial data messages.
    • The EBCM applies brake pressure to the slipping wheel in order to transfer torque to the gripping wheel.
    Vehicle Stability Enhancement System (VSES)(stabilitrac)
    The vehicle stability enhancement system (VSES) adds an additional level of vehicle control to the electronic brake control module (EBCM).
    Yaw rate is the rate of rotation about the vehicle's vertical axis. The lateral accelerometer measures the sideways acceleration of the vehicle. The VSES is activated when the EBCM determines that the desired yaw rate and lateral forces do not match the actual attitude of the vehicle.
    The desired attitude of the vehicle are calculated from the following inputs:
    • The position of the steering wheel
    • The speed of the vehicle
    • The lateral, or sideways acceleration of the vehicle
    • Yaw rate of the vehicle
    • Master cylinder brake pressure
    The difference between the desired yaw rate and the actual yaw rate is the yaw rate error, which is a measurement of oversteer or understeer. If the yaw rate error becomes too large, the EBCM attempts to correct the vehicle's yaw motion by applying differential braking to the appropriate wheel. The amount of differential braking applied to the left or right front wheel is based on both the yaw rate error and side slip rate error.
    The VSES activations generally occur during aggressive driving, in turns, or on poor road conditions, without much use of the accelerator pedal. When braking during VSES activation, the pedal pulsations feel different than the ABS pedal pulsations. The brake pedal pulsates at a higher frequency during VSES activation.
    Quote Originally Posted by snowmanG6 View Post
  8. #8
    Rocket Scientist Photobucket
    Photobucket
    Photobucket
    Photobucket
    G6er 4 Life!
    popsicle's Avatar
    Jul 2007
    Daytona Beach, FL
    14,220
    Name
    Bryan
    Year
    2008
    Make
    Pontiac
    Model
    G8
    Trim
    GT
    Engine
    6.0L V8 L76
    Transmission
    Style
    Sedan
    Color
    Black
    I actually like getting it to kick in on a nice wet road with some puddles, To get it a little out of shape and have it correct.
    '08 G8 GT... 1 7/8" Kooks Blue Ceramic Coated Long tube Headers... 3" Xpipe...Magnaflow axle backs...Rotofab CAI...Heater hose relocate. Ported throttle body, intake manifold and Tune
  9. #9
    Photobucket
    G6 Post Whore
    ragingfish's Avatar
    Oct 2006
    4,511
    Name
    Mike
    Year
    2009
    Make
    Pontiac
    Model
    G8
    Engine
    3.6L V6 LY7
    Transmission
    5 Speed Auto
    Style
    Sedan
    Quote Originally Posted by ahuhn
    Wow, that dissertation is a yaw...n!
    Sorry, couldn't resist.
    Interesting though, how it works. Because reading what it does and thinking about the sound I hear when it kicks in, it doesn't sound like it's doing anything to the engine. Actually, thinking about it, the sound my car makes when TC kicks in reminds me a lot of the sound a plane makes when the landing gear is raised or lowered.
    2009 PONTIAC G8
    MAGNETIC GRAY METALLIC
  10. #10
    Photobucket
    Photobucket
    G6 Post Whore
    zlatsky's Avatar
    Jul 2008
    Houston
    5,491
    Year
    2008
    Make
    Mitsubishi
    Transmission
    5 Speed Manual
    Style
    Sedan
    XBox LIVE Gamercard
    zlatsky
    I can definitely feel when tc comes on but my car doesn't make any noise
    G6 - 240sx - Lancer - 325is
    Want a 510 next
  11. #11
    Photobucket
    G6er Addict
    Jan 2008
    Clearwater, Florida
    2,652
    Name
    Jim
    Year
    2007
    Make
    Pontiac
    Model
    G6
    Trim
    GT
    Engine
    3.9L V6 LZ9
    Transmission
    Style
    Convertible
    Color
    Blue-Gold Crystal Metallic
    Mine sounds like something is falling off.....................a weird grinding/vibrating noise.
    Blue Man Group Member NY Local 123
  12. #12
    Photobucket
    Medium-Rare G6er
    Kydizzle's Avatar
    Dec 2008
    Tacoma, Washington
    472
    mine also makes a wierd ass noise when it kicks on especially in the snow it makes the noise loud
    2007 G6 GTP - Fully Modded - Traded In
    2008 Silver MS3 GT - PTP SST, CP-E HPFP, CP-E Nano, Cobb TIP, Cobb FMIC, Cobb AP, Denso ITV-24, CNT Exhaust, Corksport DP, SU Test Pipe, HKS BOV v3(Recirc), AWR RMM, JBarone SSP, SU Shifter Bushing, E4 Shift Knob, CP-E Towplate, Cobb Lowering Springs & Sway Bar
  13. #13
    Photobucket
    Medium-Rare G6er
    Feb 2009
    109
    Thanks for the info guys. I think I have the regular traction control, since my car has a "TC" button next to the cigarette lighter in the front.
    Do both versions have the same button?
  14. #14
    Photobucket
    Active G6er
    Apr 2008
    Ankeny Iowa
    583
    Quote Originally Posted by Beodude123
    Yes. Same button they just work differently. You have the NW7 traction control. I don't know way they don't make the SE and GT the same but they don't.
    Mark.
  15. #15
    Photobucket
    Medium-Rare G6er
    Feb 2009
    109
    Which one is the NW7?
